Prop pitch
1 Post
If talking Merc 500HP or 500EFI and Bravo prop, you will need a 26". Remember the 24" is just about 23" stock. Is your drive ratio 1.5 or 1.36? Speed will be low to mid 70's.
If you have 500hp then I would say a 26p B1 as well. Do you know at what RPM your engine makes the best/most power? That will determine what RPM range you want to be in at WOT and lead you to what size prop you will need.
