Bilge Lights?
bilge lights
I bought some from West marine.They are LED with 3 bulbs,that are switchable red or clear light,and they are fairly bright.You just need to fabricate a mounting bracket.I used 3/16 aluminum plate drilled a hole for the light,then bent a slight angle on them and mounted them on the under side of the side rails on the engine compartment.If i remember correctly tey are about 75.00 each. 2 are plenty.Hope this helps.
if the light in question is the round housing, perko makes it in plastic and stainless steel. Only one number differs in the model number. Stainless ones are twice the cost of plastic. I replaced some in mine.
