Festoon LED's for Fountain Cockpit lighting
i just got some from superbrightsleds.com but they were 42mm. part # was 4210-RHP6: Red. Installed the other night and they lit the cockpit very well. One at the back seat and one under the helm. If your lights are different, you can try a chat session with their tech support, give them the part # of the bulb you have and they will tell you the equivalent. Hope this helps.
Side note.....Doesn't the word festoon make you laugh. The first time I heard what those bulbs were called I started laughing.
Regards,
Dave
That LB1 model says 13 VDC maximum (not for automotive applications). What did superbrightleds.com have to say about that? Are they actually ok for automotive charging systems?
Thanks (looks great, by the way!).
Terry
Terry
Ginger or Mary Ann?
chances are they be ok as long as you don't plug in a battery charger that has a high rate charge stage with them turned on, or a really low battery with alt putting out high rate to recharge
