Stereo Amp Location >
Stereo Amp Location
Stereo Amp Location
Old 11-20-2012, 03:22 PM
The other thing you could do with mounting the amps on the mirror you could put fans on them and get a piece of the mirror and make a false panel so it hides the amps. I thought about doing this just havent yet.
redsled33 is offline
Old 11-20-2012, 04:01 PM
On Time's Avatar
Originally Posted by mikesystem01
i got both mine mounted down under the sink area and easy to get at and there not small amps either plus the wires are closer to the deck
Bingo. Me too.
On Time is offline
Old 11-21-2012, 07:28 AM
There a picture of mine in mirror place, we made another smaller mirror and its perfect, also fit fridge and TV 22 ,lol
Quebecfountain is offline
Old 11-21-2012, 07:39 AM
Where did you get that fridge?
My amps are in the side compartments of the cockpit. never had an issue with heat of water, and I got stuck in the rain a few times this past season.
I am also considering building an amp deck that hides the wires and installing above the sink as well. Easy access and more bling to show off
4bus is offline
Old 11-21-2012, 08:06 AM
I found portable fridge / freezer, check at this link above, mine is other name but i think is like CF40 or CF50 (not sure now), 12 Volts & 110 Volts, automatic change
http://www.pplmotorhomes.com/parts/r...zer-fridge.htm
Old 11-21-2012, 02:47 PM
Default amps
What size is your boat? On my 35 I put them in the bathroom, on my 29 they are under the bar, never had any issues with them shuting off.
Philip Carnell is offline
Old 11-21-2012, 03:18 PM
need to remove all stage of plexiglass on the bar to win space where you put amps,
also cut little bit radio frame on top to fits amps on the top
and for sure need rectangle amplifier to fit in that place,
Old 11-21-2012, 03:29 PM
