1998 fountain 32' toggle switch breaker >
Old 09-16-2013, 05:36 PM
Default 1998 fountain 32' toggle switch breaker
Hello new to me a 1998 32' twin 502's, Question how do you reset the dash toggle switch breaker's? 2 of the toggle switches will not power up . 1 bilge & anchor light. When i jump across the breaker the pump will run & rear running lamp will come on. Thank you
opelgt327 is offline
Old 09-16-2013, 08:48 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Those are just toggle switches, not breakers
The breakers are under the rear seat, push the red buttons to reset.
US1 Fountain is offline
Old 09-17-2013, 10:35 PM
Paneltronics
206-052S
Waterproof Circuit Breaker, Single Pole, 10 Amps. This is what's under my dash thank you JD, Order 2 new ones.
Old 09-18-2013, 10:12 PM
Ginger or Mary Ann?
You are indeed correct, they are breakers there. Just took a peak at mine to double check.
Old 10-23-2013, 06:48 PM
Hello : Tyco Potter & Brumfield W31-X2M1G-20 Toggle Circuit Breaker, Is the type & brand used on 1998 32 ' fountain. The other ones listed would work but you would have to change the wiring around a little bit. Didn't wish to mislead anyone. John
