Fountain 32 Fever Wiring
Have a 2000 Fountain Fever with twin 502's
Trying to find a wiring diagram for the ignition switches
Power is not getting to the switches so I am trying to find where it starts
Thanks in advance
Thanks in advance
Ginger or Mary Ann?
Motors will still crank with the lanyards pulled, just not fire.
pop open the rear seat. There should be some resettable fuses under the back seat. Push them all in and make sure that they are all reset. You should be all set. I have had that happen to me a few times.
I have tested the circuit breakers under the seat. All are working properly
One switch has a red wire and the other has a red/white wire
Need to find origin of the wires and how they get power
Trying not to open the harness to trace back
Hello ![Smilie](/forums/images/smilies/smile.gif)
Iam a new owner of a fountain fever 27 with 540ci 600hp Carb engine.... I was on the water yesterday cruising at 3200rpm going back to the marina... when i started pulling the throttle back all of a sudden my engine ruined the plugs and came runing rich.... i towed the boat home and noticed that a wire from the neutral safety switch went out... everything was working except the engine wont crank... Do you guys think the problem came out from the neutral safety switch wire???
Thanks and await your kindly reply
still a beginner
still a beginner
Ginger or Mary Ann?
Are you stating a wire from the safety switch fell off the switch? If so, yeah, that'll keep the motor from cranking. (Motor thinks the drive is in gear)
Ginger or Mary Ann?
Not understanding that part of the post. Language barrier thing.
If the wire fell off, the N safety switch would be 'open'. just like he was driving around. Only problem would be when he shut the motor off, it wouldn't crank over to restart since the wiring would be an open circuit. Not sure how the safety switch has anything to do with the motor dieing and fouling the plugs from being rich in a split second.
