NXT#6 Oil change quantity
Hello ,
I will changing both my drives and trans NXT#6 , i plan in using the new Mercury racing gear lube but any help with the quantities i need ? And parts that need changing (like drain plugs fill plugs , washers etc...)
Thks
Sherif
Thks
Sherif
Are they 6's or nxt? Or 6's on nxt transom assemblies?
NXT trans holds 1.1 qts., the #6 drive will require approximately 4.5 qts. to fill, without filter change. Fill through bottom till it comes out the top level hole. With filter change, you must spin propshaft 80 or so revolutions to prime/fill oil system to finish filling drive to correct level.
