Reversion problems with 47's with 525EFI's...
I have a side by side 35 not a 47, but the relationship of engines, transoms, and exhaust should be the same. I have the silent choice option, there are internal flappers up in the exhaust pipe and the Salisbury style flappers on the tails, all factory set up, never any problem. My 35 has a very high X, your triple engine boat should have the outer engines up there pretty well I would think. Do you have the internal flappers up in the pipes? Have you tried Fountain, or maybe Brian Forehand @ Marker 17 for some thoughts.
Another thought, In the pipes there are some small reversion baffles, lack of right name here, that are there to stop the water from creeping back up the pipe, have seen some talk on here that sometimes they break loose and exit. Might be something to look for.
Also make sure you have no exhaust leaks. Any leak will promote reversion especially at the header/head. It's doubtful that's the problem since it's on both motors and same cylinders on both but you need to rule out any leaks.
I can't help but believe that it's something simple that we're missing. 525s with basically dry tails should not be walking water that far up the pipe. I'm anxiously waiting to hear how things go this weekend. Hopefully without issue as I know you've stayed on top of everything with those motors. Hoping for the best.
All of my header to tailpipe connections were bonded with gaskets and Ultra Black RTV to completely seal those connections. Headers were installed with all new gaskets and torqued to Merc. spec. Could there be a leak, sure, but I highly doubt it. I have also ruled out leaks in the headers themselves as I've pressure tested them all extensively.
Couldn't agree with you more!! Thats why I was so surprised to see it.. I thought I solved that problem for sure with the dry tails..
Call David Rank at CMI , tell him you want some reversion cones made to fit between the header & tail. If he doesn't know what your taking about have him call me. The problem you and other people have can be two fold. If you boat in cold water, the tails will condensate, and the pulsing from the exhaust at idle will walk water up the outer inside of the tailpipe Or extended idle periods.. What I would always tell people to do if they had to idle for any extended periods, was to put that motor in neutral and rev it up a bit to clear it out. I have tested with success using mufflers to change exhaust pulsing, and elevating water walking up the tails. But reversion cones work too. Cheapest way is to just clear it out every so often.
