x dimension advice - staggered 42 fountain (non step)
Bout to cut new transom. Need advice.
Reggie lll suggested 1" under with 5 blade maximus props.
Anyone else ??
Smooth bottom boats run fast by carrying the bow right? Will the boat carry the bow with that shallow x?
I could always run spacers to fine tune
Thanks in advance
Anyone else ??
Thanks in advance
At 1" under I doubt I'll get water pressure I need without lwp....and I'm trying to run standard bravo lowers. Don't wanna hafta buy new lowers....or the more expensive lwp lowers down the road .
1 mph is worth it to me.
What pickups are you talking about?
Reggie makes a single pickup that feeds a big single strainer that will feed both engines. They run a air bleed off the top of the strainer makes a real neat set up. It's the same system they used in their race boats.
