42 fountain lift help
Hello all,
I own a 2005 42’ fountain executioner with staggered 525 EFI’s, standard drives, and no standoff boxes. The boat does not have a generator or air conditioning. I am looking for information for a recently purchased boat lift. The lift is a hydro hoist, and I need the center of gravity, as well as any bunk recommendations. Does anyone have experience they can share with their 42' lift?
I have a trailer now, which I will duplicate as much as possible. Just looking for any and all information prior to starting the project.
Thank you very much in advance for any help you can provide.
If my memory is correct, I saw a diagram of Fountain's recommendations for boat lift bunks (probably same as trailer bunks). Not sure where I saw it, however.
Just make sure you do it so that the hull is support properly (to prevent a hook in the hull from long term storage).
[ATTACH=CONFIG]561347[/ATTACH]
I've have had my 42 on a hydro hoist for a few years , mine is 15k side tie, I'm not sure how your lift is set up, but on mine the rear bunks are adjustable & run from just behind the rear step all the way to the transom , you can kind of see what I mean in the pic, the front is just supported by a V style bunk , this is sort of how the HH lift works , as it goes up the bow just falls into place, Its not the perfect set up , but I think the rear of the boat is supported well, I'm not sure if a cradle would wok on a Hydro Hoist
My current lift has this exact set up. I plan to add a couple extra supports, which I am sure will be over kill.
