Fort meyers Poker Run
There were a few delays with parts so I decided to just move the center motor over to starboard side to have a balanced boat. New motor will be finished next week, then they can start on the other 2. Also am pulling off the lower unit and putting a plate on to reduce drag. I think we will be able to run 80 MPH which will be quite OK. If I can run in the middle of the pack I will be quite happy. Will let you know how it all turns out.
Bob
Bob
1 Post
Hey Bob, that is the advantage of having 3 to choose from and any two will work.
We did our shake down today up to Captiva for a late lunch. Everything went well. Need some slight carburetor adjustments. Heading for either Naples of back to Captiva tomorrow afternoon if anybody is going to be out running around.
I am planning on taking some people out for a ride around 2 or 2:30 if that works for you Dennis. I will check with you once I get my slip and room to see if you are going north or south. See you soon.
Bob
Hey that's me in the cowboy hat, trying to be a good crew member, I did not realize I was so much taller then everyone else
I can't believe you get in that close with your lens, never even knew a photo was being taken
J-Bonz
06-14-2008 10:07 PM
