Anyone know about Nextrail Trailers?
Forum Regulator
My last trailer was a Rocket Trailer. Total trash. I would not even have used it to cart around a woodshed. It had 'Quality Axles' on it, which were ANYTHING but. They were rated for 3500 lbs. and I had exactly 7000 lbs. on the trailer when (trailer & fuel included). They were both trashed within a couple years. I had to replace both of them due to bent spindles.
I also highly recommend Kodiak Disc Brakes. Most of the trailer manufacturers offer them. I think they are step above the Tie-Down Engineering Brakes. Go with the Stainless Steel Calipers with Nickel Cadmium Rotors (dual plane, with cooling fins, much stronger and less prone to warping. This is the most popular combo, but you can get Stainless Steel Rotors for BIG dollars. Tie-Down Engineering uses a single plane rotor which is thinner, weaker, and more prone to warping. Their SS kit includes a SS rotor, but the caliper is the weak portion on the Tie-Downs as it is plain Aluminum and prone to corrosion.
My strife on my last trailer:
http://www.offshoreonly.com/forums/s...ghlight=kodiak
Thanks for the responses. I bought the trailer. I went with Gary's recomendations, triple axil, leaf instead of torsion, drum breaks/electric on 2 axils, 10,500 lb. Lifetime warranty, 5 yrs. on brakes. $ 4304.00 to my driveway.
Member #154
21 and 42 footers
I'm with you Sydwayz......we tried.
Pure Energy. Good Luck, hopefully in your case we will be wrong.
Forum Regulator
Rockets are/were the biggest piece of sh!t in the aluminum trailer arena. They are not all like that. Other than Rocket, aluminum trailers have proven to be useful and dependable. Let's face it brakes, couplers, winches, lights ect that you choose are all from the same vendors, regardless of the trailer brand you choose.
Good luck with the trailer. I'm quite sure you'll be satisfied...
they are low cosmetic maintenence and keep the total wieght of the package down compared to steel.
it's easy for these guys to spend 10-12K of your money.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
Forum Regulator
Never mentioned Myco, or anything like that. I just highly suggested over engineering it capacity-wise a bit; which he did as PE has a 31' Sonic.
You guys might be wrong in assuming that a 10,500 lb. trailer has 3-3500lb axles. My Manning trailer (which is rated for 12,000 lbs.) has 3-6,000 lb. axles.
Forum Regulator
That's because your heavy ass lead filled crap heap weighs 4000 lbs.
Honest, I don't know their exact way for making the ratings, but I know it starts with the axles.
