What's the best cleaner for seats?
there are several manufacturers and grades of marine vinyl in terms of chemical make-up. Avoid anything with a solvent in it as vinyls are a petroleum product. Test an inconspicuous area first. Westleys is effective. SoftScrub leaves too much residue to rinse away. Baking soda is relatively inert and safe. I have always used spray nine with excellent results, no negatives I have ever seen over 15 yrs and six boats. For tougher stuff you have to let it set and soak, or multiple applications. Don't forget...be patient, a couple of days in the sun will take care of the mildew stains. The UV will bleach 'em right out!
haven't tried the magic eraser yet...remember dont rub so hard with something like that to the point you scuff the "gloss" off the vinyl, or flatten the grain.
I'd give it a mellow once over and then out in the sun for a couple days...then you'll know what's left to be dealt with. You'll be suprised what the UV will do. Though this early depending on where you are the UV isn't that intense yet.
What about after your done cleaning, do I need to put a conditioner on the seats and stitching to keep it soft.
THe Maguires sounded good because it has a conditioner in it already.
I'm going to buy the Spray Nine and the Magic Eraser today and try it tonight. Maybe I'll try the Baking Soda also. I'm just concerned about using a wheel on the seats and burning them. I realize just like the fiberglass, you have to keep moving.
Originally Posted by RichardP
THese Magic Erasers will make the seats white again?
Does Wall Mart sell these?
Do you need to beleave in magic for these to work?
![Bunny](/forums/images/smilies/bunny.gif)
Someone told me that he used clear Chap Stick on the stitching and then wipe it with clean rag to prevent water from getting in, anyone heard of this and does it work?
303 for conditioning...recommended most by vinyl manufacturers.
you've got the right idea, start out mellow and don't forget the UV...UV is a non chemical bleach.
![EEK!](/forums/images/smilies/eek.gif)
A lot of cleaners do a great job on the vinyl but kill the stitching. If you use the wrong stuff your seats will fall apart by the end of summer...
