both engines wont run at the same time
You Have a bad ground at the battery or on of the blocks Question do you have two alternators or one? if 1 and you have a bad ground the second engine would die.. same if you had a loose positive wire (just check all connections and if there clean)
Charter Member #232
Jon
Put your best foot forward!
Could be fuel flow too. I had a bad fuel pump and when I had one engine running the other would start, but not crank past 1200RPM'S or it would just die. Check the fuel filters too...just in case all this battery stuff doesn't solve the problem.
Sydwayz
09-25-2007 07:16 AM
Mr Gadgets
17
10-17-2005 04:55 AM
THRILLSEEKER
06-05-2002 07:52 PM
