Hitch me up - trailering question >
Old 04-28-2005, 10:01 PM
dockrocker's Avatar
Default Re: Hitch me up - trailering question
Reese makes the parts I was originally going to user, unfortunately the local shop does not have them in stock.
However, they do have equivalents from Draw-Tite. Solid stainless steel "stinger" rated for 12K, 2 5/16" ball rated for 10 or 12K. I originally ordered a 4" drop, but I think that may be too much. I'll see if I can get a 2" version. I didn't know about the 18" rule of thumb, that will be handy.
dockrocker is offline
Old 04-28-2005, 10:40 PM
Mine is a Load Master trailer and they set up on 21''.check with the man.of the trailer if in question.
FloridianSon is offline
Old 04-29-2005, 01:40 AM
cgarrett's Avatar
http://www.ultrahitch.com/perfect_drop_bar.html
http://www.ultrahitch.com/rapidhitch.html
http://www.clever.ws/hitch.htm
Go to
http://www.draw-tite.com/
Click on Forged Ball Mount
Then Click on Hitch Balls
They have the size you need.
Go to a Trailer/Camper place they will have stuff like this in stock.
cgarrett is offline
Old 04-29-2005, 02:48 AM
Forum Regulator
Sydwayz's Avatar
Received 1,255 Likes on 548 Posts
http://www.offshoreonly.com/forums/s...ad.php?t=78812
Sydwayz is offline
Old 04-29-2005, 06:23 AM
Buy the solid square receiver. Those hollow ones I think aren't rated high enough for you.
RichardP is offline
Old 04-29-2005, 06:26 AM
ofshore's Avatar
dockrocker, read through the thread sidwayz just posted it has a lot of good info, in order to pull 10k legally you would need a weight distributing setup. I just went and checked mine it's a class V hitch rated for 15k but if you don't have the weight distribution setup (and I don't) it's only rated for 6k weight carrying .
ofshore is offline
Old 04-29-2005, 07:05 AM
OldSchool's Avatar
That depends on the size of the rims and tires. Mine is level at about 21" as well. They are making some really cool adjustable receiver/ball setups these days out of billet.
OldSchool is offline
Old 04-29-2005, 03:41 PM
Mike,
When are you going to get the boat ? Mine may be available to use, 2 5/16 ball and slide in receiver.
ed
Interceptor is offline
ActiveFun
05-26-2006 10:01 AM
Boomer35
13
11-11-2005 07:04 PM
BZ
5
06-23-2005 03:53 PM
OldSchool
09-15-2003 07:47 AM
JHR
01-21-2002 08:18 AM
Quick Reply: Hitch me up - trailering question
