outboard guru's
Old 06-23-2005, 10:27 AM
Brad Zastrow's Avatar
Default Re: outboard guru's
Replace the case. If you crack it again you risk losing the gears and bearings from the water that will get in. Look for a used case on Scream n Fly.
Brad Zastrow is offline
Old 06-23-2005, 07:33 PM
berns29scarab's Avatar
well guy it isnt looking good for Saturdays Poker Run but i'll know for sure tomorrow. The guy attempting to do the repair was testing his own boat today...
berns29scarab is offline
Old 06-23-2005, 07:34 PM
its a counter rotation 20" sportmaster. having a problem finding one..
Old 06-23-2005, 08:56 PM
Bern definately repair or replace the case. If the crack walks it will take the internals.
KenP is offline
Old 06-24-2005, 04:10 PM
Tabasco Cat's Avatar
Bern,
If i'm not mistaken did I see your rig on trailer gettin set to be pulled out of Proroc around 3:30 friday. I believe there was a 35 Motion that looked like it was set to be pulled too. Hopefully you got the repairs you needed. If so enjoy the weekend down in AC
Greg
Tabasco Cat is offline
Old 06-24-2005, 09:30 PM
LOOK AT THE LEAD NOW!!!!!
DPT MOTORSPORTS's Avatar
I am sure Bern will post later but just got back from his house and he is all welded up and ready to run in the NJPPC Atlantic City Poker Run tomorrow. He has everything covered now. Thanks to all of you that tried to lend a helping hand to a good friend of mine.
DPT MOTORSPORTS is offline
Old 06-24-2005, 09:37 PM
no it wasnt at Proroc this weekend, got the lower back from the welder at about 6, changed fluids in both lowers, installed and ready to rock. lets hope she holds up...looks like he did a helluva job. cleaned, drilled and glass beaded the exisitng crack both on the interior and exterior, then welded an aluminum plate along the rear between cavatation plate and carrier housing. if it holds i'm going to have him do the other one as preventative maintence...i think. Thanks to all who chimed in and if i ever catch ya at the bar I OWE YOU A DRINK !! THANKS AGAIN TO THE POWER OF OSO !!
Old 06-28-2005, 12:06 AM
heres some pics of the repaired lower. drove it like i stole it round trip to AC for the NJPPC Poker Run and not a mark.
Attached Thumbnails outboard guru's-dscn2674.jpg   outboard guru's-dscn2675.jpg   outboard guru's-dscn2676.jpg
Old 06-28-2005, 12:19 AM
OSO Content Provider
Commercial Member
SHARKEY-IMAGES's Avatar
One thing about Cats, they are real hard on lowers.
Especially if you have a center engine...
You don't need to worry about that...
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 07-05-2005, 11:58 AM
Tantrum's Avatar
ttt
Tantrum is offline
Quick Reply: outboard guru's
