598ci Dyno Numbers
Nice numbers! Be careful with that 38 degree timing setting. Dyno and boat are not exactly the same. Particularly when running WOT for extended periods. I run a similar 598 using Dart 355 CNC heads, solid roller, 10:1 and a larger carb. It runs very strong at 32 degrees of timing. Good luck!
Craig
Craig
My Y2k had a procharged 500 in it at one point and they said they were running 94. Supposedly pushing 750 HP. If that's true.....well, you better wear a PFD!!!
