Ran out of Gas!
Charter Member #232
Originally Posted by f311fr1
I installed the Livosi senders in my Black Thunder. 1/4 on the gauge = fillup. They do seem to be very accurate, or at least more accurate than the stock side float style. Joe Murray
Jon
Put your best foot forward!
www.hyperfishing.com
Gauges on the boat are like the one in the car, 3/4 full means half empty!
The good news is that it seems I drive for free for a long time, then reality kicks in......the guage needles drop down minute by minute.
Recording flow meters work a lot better than the fuel gauges do. Floscan is the granddaddy, and has a number of options (check out at floscan.com). Standard/Horizon used to make one, the FF-41, and it's still listed on their website. Lowrance has a couple of options that are part of a multifunction system (combine with ambient water temp so you know what you're jumping into?), and there's a Navman out there as well.
If you go with an adjustable sender like a Tempo and set it precisely like they tell you to, and do not hit any baffles you can end up with a fairly accurate fuel gauge, but you also need to sweep test it before install to make sure the sender and gauge jive. (i.e. when the sender is half way up the guage says 1/2) It takes a little time and some measurement so most of the maunufacturers just wing it.
wrasse
03-12-2022 03:39 PM
JBoat
07-01-2008 05:42 PM
Pro1
11-23-2006 10:08 AM
