Hull protection when traveling? >
Old 11-27-2005, 12:32 PM
Downtown42's Avatar
Default Re: Hull protection when traveling?
what brackets do you use US? Got pix of how you rigged?
Downtown42 is offline
Old 11-27-2005, 12:37 PM
jordy's Avatar
Originally Posted by Downtown42
That is different. Took me 2min to see what you were explaining. thanks.......Do you use the nets for smelt fishing?
Sorry, those are the best pics I have of the trailer. Lots of pics of the boat on the water though. Haven't caught anything with the nets yet, other than rocks off the road.
jordy is offline
Old 11-27-2005, 12:52 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Do now. Basically it is just a peice of 1x1 angle iron that extends the full lenght, with 2 short peices welded to it that extend downward along and past the 2" reciever with a bolt under the bottom to claamp it tight. I installed the 2 diagonals not knowing if I needed them. Like I said, not pretty but it works great.
US1 Fountain is offline
Old 11-27-2005, 12:57 PM
Downtown42's Avatar
Thanks! Looks good to me...add some silver naked women and you'll be stylin
Old 11-27-2005, 01:19 PM
AKA NoMoBoatin
Can't be worse then this...
Downtown not as bad as that but close.Mine is a hard vinyl that has 3" slats the whole way across except where the receiver is just like the ones R.V 's use.
docmanrich37 is offline
Old 11-27-2005, 01:27 PM
Downtown42's Avatar
119. Gravel Guard
http://www.gemplers.com/a/shop/produ...4282&T1=134084
Old 11-27-2005, 05:51 PM
Masher touches my
Outdrive1's Avatar
That's how I made mine as well, a piece of angle iron, mud flaps from a truck supply place and a u-bolt that goes around the bottom of my receiver with 2 holes in the angle iron. All the weight sits on your receiver so the u-bolt basically just holds the angle iron from moving. Cost me about 40 or so dollars with the mud flaps being the most expensive part. Just cut them down to the size you need.
Not the greatest picture but you can see them on the truck, I bought blue mud flaps to match my blue trailer and put some crome brackets on them so they wouldn't sail. They sit about 2 inches from the ground and have no problem covering up those 40" tires....
Outdrive1 is offline
Old 11-27-2005, 05:56 PM
OSO Content Provider
Commercial Member
SHARKEY-IMAGES's Avatar
Talking Re: Hull protection when traveling?
Shrinkwrap the bottom......
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 11-28-2005, 01:26 PM
Downtown42's Avatar
yur killin me
thank you for all suggestions
Old 11-28-2005, 02:18 PM
Warped & Twisted Member
Jamie B.'s Avatar
These have adjustable arms to raise or lower the height of the flaps. 240 bucks.
http://www.genosgarage.com/CoastalDa...D=1607&CATID=1
Jamie B. is offline
Quick Reply: Hull protection when traveling?
