Anyone using SmartCraft 1000 or 5000?
I'm curious to see if anyone is using this system exclusively on their performance boat?
I like lots of gauges as much as the next guy, but am considering replacing all of them with SmartCraft...it would give me room on my dash for a GPS...
pics would be nice too...please post if you are using the SmartCraft stuff.
Re: Anyone using SmartCraft 1000 or 5000?
I had a demonstration of it in a fountian 42 PR and it is pretty trick, however the regular gauges are easier to tell if something is out of whack at a glance. I think it is a very nice suplement but I would still want the basic engine gauges like what you are seeing in the above pics.
I have a full gauge display on the screens of the gps's. Looks just like the analog. You can toggle between the two screens for nav, gauges, video, etc. If using just the smartcraft display I would still keep the full gauge set up.
At bare minimum keep a monster tach and gps speedo for each motor. They are much easier to read at speed. The Smartcraft system works well and be programmed to slide show display in any order you choose with adjustable delay for each screen if you want a longer view time for a particular function. You can also bundle 1 to 4 separate screens into one as well.
Terry, how does that unit look in the sunlight? Is it easy to read?
I'd like to go without gauges completely...even fuel...do they hande the fuel level also?
Trout...thanx for the pix...kinda gives me an idea of how it looks...
Sunlight is no problem. So far the only Smartcraft compatible GPS that I know of is the Northstar 6000i Series.
Smarcraft handles every function including fuel info. You could even eliminate the drive/tab indicator as long as you have the new Mercury parts.
British member!
We run the standard speedo and tacho plus a sc 5000 - we find it not so good in direct sunlight and it will accept any GPS with NMEA 0183 output.
Navman are now producing a GPS and a GPS/Fishfinder with built in Smartcraft technology, so you can get all the readings you want from the motor as well as GPS info on on unit. We havn't tried that yet, but considering it for the 2006 demonstrator boat - it's a cheaper option and takes up less space overall.
Cookee
If it's too loud you're too old!
BananaShark Racing
British Champions 2005!
Cookee
BananaShark Racing
