Powered by Lamborghini
Old 01-17-2006, 12:39 PM
  #31
thisistank's Avatar
Received 3,259 Likes on 1,055 Posts
Default Re: Powered by Lamborghini
Don Johnsons old 43 scarab that had the Lambo motors was here in Ventura for years. It sold a couple of years ago and is now back east somewhere (LOTO maybe?)
thisistank is offline
Old 01-17-2006, 12:41 PM
  #32
X-Rated30's Avatar
The European boats look a good bit larger than our supercats. Which are faster and why?
Also, you never see one of ours simply blow over like Maritimo does in that vid. What's up with that?
X-Rated30 is offline
Old 01-17-2006, 12:44 PM
  #33
platinum's Avatar
Originally Posted by Edward R. Cozzi
Hustler had a 50' with Lambos and Arnesons in the mid-nineties. Wild rooster-tail and 102 MPH with the engines loafing. Sound was very quiet at idle, but outrageous any other RPM. Was fun to drive.
Today these engines are in California, awaiting their new home in a platinum...
platinum is offline
Old 01-17-2006, 12:48 PM
  #34
A to Z
Sean H's Avatar
they are roughly the same size as our supercats (all new boats are between 40'-44' and older boats are grandfathered in at 39'4"-48')....the 44 mti runs over there and is basically the same as the supercat mti with a bustle and rudder... due to restrictors on the engines, they run the boats as loose as possible, really loose.... especially MP's latest creations (the latest rash of photos of the victory boats flying upside down and backwards...) and they are running much faster race speeds than our supercats...
Sean H is offline
Old 01-17-2006, 01:02 PM
  #35
Originally Posted by Sean H
the boats have a potential speed of around 170-175, but probably not propped that way for most races....they run restrictors on all those engines to keep the speeds down and to help allow teams to run different engine combos (with restrictors the 1075 makes about 950 HP)
The UIM record with restrictors on is 160 and change.
Restrictors removed probably in the range you qoute.
MikeyFIN is offline
Old 01-17-2006, 01:09 PM
  #36
A to Z
Sean H's Avatar
i went looking for the speed record for class one, but its not listed anywhere on UIM website?
http://www.uimpowerboating.com/vsite...m-item,00.html
Sean H is offline
Old 01-17-2006, 01:24 PM
  #37
RedDog382's Avatar
Heard a Lambo motor running on the dyno one day at Sterling Performance a couple years ago. Sound is awsome and unmistakeable!
RedDog382 is offline
Old 01-17-2006, 02:28 PM
  #38
ApachePete's Avatar
I (Allez Vite) couldn't keep up with that boat in a poker run in the early 90's on Lake Michigan. And he had 6 people on board!
ApachePete is offline
Old 01-17-2006, 02:31 PM
  #39
ApachePete's Avatar
Originally Posted by BattleCry
A friend of mine as ran them for years in his pleasure boat. Good Luck trying to get them rebuilt here in the U.S. They scream. I believe Don Johnson had a set. I also know that Mercury Racing did alot of testing of them in the late 80's and early 90's.
There's a pair of them on the floor At Innovation Marine right now.
Old 01-17-2006, 02:38 PM
  #40
what is the cost on any type of lambo marine engine?
PurpleStuff is offline
Quick Reply: Powered by Lamborghini
