hood scoop or not to hood scoop >
Old 01-24-2006, 07:48 PM
375stinger's Avatar
Default Re: hood scoop or not to hood scoop
Originally Posted by johnnyboatman
yes but what hes talking about will not fit under a hatch like that, I'm going thru the same scenario. adding 871s and innercoolers. the scoops will have to be so tall they will look like crap.
exactly! the flame arrestors already hit the hatch....once you add big blower and intercooler its gonna be sticking high out of the hatch.....
375stinger is offline
Old 01-24-2006, 08:22 PM
johnnyboatman's Avatar
im doing mine, i think i will try to let the carbs and air cleaner stick up thru the hatch for now, trying to find some different scoops.
johnnyboatman is offline
Old 01-24-2006, 08:23 PM
cuda's Avatar
Originally Posted by US1 Fountain
That's sharp, but he looses the use of the swimplatform in the conversion.
Yep, his wife was not real happy about that.
cuda is offline
Old 01-24-2006, 08:32 PM
375stinger's Avatar
[QUOTE=johnnyboatman]im doing mine i think i will try to let the carbs and air claener stick up thru the hatch for now, trying to find some different scoops.[/QUOTE
what boat are you doing this on? do you have any pictures of it so far, or are you just getting into it? if we have flame arrestors that were partially protected by those metal scoops that go around the flame arretors, what would be the main problem of having the engine open, as long as it was covered when it was parked? its ran in fresh water all the time, and the big canopies up front are still probably going to be taller than the engines sticking out. is it the blower and carb your worrying about, or just the flame arrestor?
Old 01-24-2006, 08:35 PM
375stinger's Avatar
something like these....http://www.cpperformance.com/detail.aspx?ID=2332
Old 01-24-2006, 08:56 PM
i will post a pic shortly, this is what i have now, but going to bigger blowers, innercoolers, and dominators facing back to back, not mounted sideways
Old 01-24-2006, 10:06 PM
Phantom1's Avatar
Call Fred at Trick. He'll set you up with a few scoops.
http://www.trickmarine.net/productde...?productid=759
Phantom1 is offline
Old 01-24-2006, 10:28 PM
Charter Member #232
Audiofn's Avatar
If you go exposed I would be super afraid of some one getting caught up in the belt. You know while docking or rafting. Perhaps you could do a little of both. Raise the hatch and also have the scoops. This way you will not have a scoop sticking way up.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-25-2006, 03:41 PM
375stinger's Avatar
thanks phantom... i think those are the ones i was looking for (i believe they are stronger than usual automotive type scoops)
audiofn: thank you very good point....docking could be a huge problem with just me and my dad trying to get to the back of the boat with 3 hot motors, and belts to get caught in...
Old 01-25-2006, 05:06 PM
Phantom1's Avatar
I've had one of them on my last two boats. They are strong.
Attached Thumbnails hood scoop or not to hood scoop-lkx1big.jpg   hood scoop or not to hood scoop-transom.jpg   hood scoop or not to hood scoop-mvc-383f.jpg
Phantom1 is offline
Quick Reply: hood scoop or not to hood scoop
