Would a Myco trailer for a Donzi 38 ZR adjust to fit a Baja 36 Outlaw? >
Old 02-14-2006, 08:13 AM
Harper220's Avatar
Default Would a Myco trailer for a Donzi 38 ZR adjust to fit a Baja 36 Outlaw?
Just curious if bunks could be adjusted from a stepped Donzi 38 ZR to fit a Baja 36 Outlaw, also how about length adjustment? This is a triple Myco trailer.
Harper220 is offline
Old 02-14-2006, 08:58 AM
stecz20's Avatar
Default Re: Would a Myco trailer for a Donzi 38 ZR adjust to fit a Baja 36 Outlaw?
sure could... just have to move around or replace the 2x6s and move the bow stop back... im sure it will take some fabrication if it is steel, if aluminum it might be a little easier.... i have my 35' cafe racer on an old top gun trailer.. fits nice, took some work to make her fit.....
stecz20 is offline
Old 02-14-2006, 09:05 AM
birdog's Avatar
Myco welds the bunk supports. so...For a stepped to non-stepped would be alot of work. Cutting & welding supports
birdog is offline
Old 02-14-2006, 09:08 AM
hammer01's Avatar
my 38zx is on a triple axle aluminum trailer and it does have padded steps on the bunks which i believe can be removed and replaced with straight bunks. i would call myco because they have the actual dimensions for correct weight displacement for the front support. i know you can call heritage and they have a diagram for the 36 outlaw which they make a lot of trailers for.
hammer01 is offline
Old 02-14-2006, 09:09 AM
stecz20's Avatar
they double up the 2x6s for the stepped boats and keep them single for non stepped... its really just the matter of shimming the lumber till it fits right...
stecz20 is offline
Old 02-14-2006, 09:41 AM
birdog's Avatar
wow....That seems kinda cheesy. I know Eagle builds them for the boat.
birdog is offline
Old 02-14-2006, 10:44 AM
DJF
Each MYCO trailer is custom made for the hull it is intended to carry. The bunk supports are welded in place and the bunks cut for the hull. I would call MYCO direct and ask them what it would take to convert the trailer.
Dave
DJF is offline
Old 02-14-2006, 10:57 AM
Rob
Strip Poker 388's Avatar
Mine is not adjustable and the bunks are not stacked.It was custom made for each application
That would hacking up a trailer to make it fit.
Strip Poker 388 is offline
Old 02-14-2006, 12:29 PM
yzbert's Avatar
i have a trailer for a 36 outlaw for sale, it even comes with the boat!!!!!!!
yzbert is offline
Old 02-14-2006, 12:41 PM
i't's not worth it i think
jr mike
thedonz is offline
concealedGSXR
09-15-2012 04:30 PM
mittens
1
02-20-2008 02:44 PM
Wild
10
11-03-2007 07:33 PM
tc 0707
03-27-2007 09:57 AM
Harper220
03-08-2006 04:40 PM
Quick Reply: Would a Myco trailer for a Donzi 38 ZR adjust to fit a Baja 36 Outlaw?
