BIG NEWS!!!!!! Whipple 5.0 liter to replace QuadRotor!!!!!
Re: BIG NEWS!!!!!! Whipple 5.0 liter to replace QuadRotor!!!!!
I wonder if you can actualy call them up and order two.
Gerry
Gerry
Originally Posted by docmanrich37
Wifes going to kill me.Strip I stopped by and talked to Dean about he's drives.I'm leaning towards his set up but I might have to do some cutting on my swim platform brackets.
You talking about the sterring mounts
Hey everybody, hope things are going well. We are actually mfg'ing our own compressors, we do not import or purchase from Lysholm anymore.
If you check out our site, there is much more info that shows the differences in compressors. Ours has many new features, but fits in the same package.
The W305 series (5.0L) is very unique compressor. It's capable of turning 16,000 rpm, is actually .75" lower than our W140ax (2.3L) quad and 1.5" lower than our W200ax (3.3L) quad. This means it has the ability to produce enough airflow for 900-1800hp! They don't need to be rebuilt, the rotors do not touch, there covered in teflon, massive double angular bearings in front to really help support the increased load, helical cut gears for precisce operation, etc.
Its been designed to work with all roots manifolds, so it will be a direct replacement for 671-1471's out there. Standard roots drive with spline shaft bolts to the front, can run 12, 14, 16 or 8mm belt systems. Available for dual carb or fuel injected, both have bypass systems built into the design.
Thanks,
Dustin
Thanks,
Dustin
Dustin that opens up your market with being able to work on the roots style manifold and pulleys .That would make a easy up grade .
Whats the hole under the compressor ?
Rob
Rob
Thanks,
Dustin
Thanks,
Dustin
Dustin do you have two instock to replace my mooney 10-71,s?
I was planning a PSI 206B with your double intercooler.
Change my mind. I am shooting for 1200 on pump gas
557 with big chiefs and Dominators
If you have them I will call you.
Thank you
Gerry
Rob
Rob
Thats the bypass flange, couples to the TB. The radial version has something similar on the back side.
Thanks,
Dustin
Originally Posted by JCPERF
How much for a 5.0 carb blower kit?
YEAH What he said
Direct replacement for the XX-71,s.
