Stepped Hull Vs Straight Hull
sandman
I recently bought a 32' nordic with a straight hull. During one of the discussions in the forum that question was asked of me but no further elaboration.
I know what a stepped hull looks like, but what are the differences in handling, turning, pros and cons? Is one better than the other for certain applications?......Casey
Simply put, the stepped hull has a section missing from the bottom. When turning the boat it will lean more because of the missing section, this additional lean along with other factors (trim, tabs, speed, water, CG) can cause the boat to lose control without warning. This has been a topic for debate for a while.
From your other thread, I posted this there as well.
It's been a big debate since the introduction of stepped bottoms, and everyone has an opinion, but generally speaking stepped bottom boats will be faster than their equivalent non-stepped counterparts, however they are inherently less stable - for the same reasons that they are faster, by introducing aeration and turbulance at the running surface, they also provide less lateral stability. The biggest difference is how they handle turns. Driving techniques are a little different, especially with how you trim the drives going into and during turns. Of course, it varies greatly from boat to boat. There are some very good, successful stepped bottom boats out there, there are also some poor ones, which can be downright dangerous.
Which is which?.....I stay out of that debate.
You can rest assured that you're in a pretty stable platform being that it is a traditional straight deep vee.
![Cool](/forums/images/smilies/cool.gif)
![Wink](/forums/images/smilies/wink.gif)
I woudn,t say twin-steps are less stable. They actually provide a much better, smoother and stable ride, plus they are faster.Their downside? You have to be more careful while turning. If you turn the boat at speed aggressively, you can hook and spin.If you drive the boat properly, they are fine.
Stepped hulls were introduced to make them faster through increased hydrodynamic efficiency. Generally speaking, that has been true. Some of the 1st generation step hulls had some problems with spinning out when turning. Even the more refined 2nd and 3rd generation versions require different turning techniques (generally leveling the drives) than similar straight vees do.
With the horsepower your boat is running (plenty), you will be fine with the straight vee, and it will be easier for you to learn to drive.
BTW, I'm not taking sides here either (I have a step hull/have owned both), just trying to help explain the situation to one of our new members.
Steve
PF Marine
People talk about how stepped hulls turn poorly, which might be true. I think it has more to do with how the outside chines are turned down or if the boat has huge chines. Another thought, when you look at Reggie's kilo run, almost none of the boat was in the water. So does it matter if that boat had a stepped hull? When you start going fast in a vee, the biggest thing for stability (control) is having matched/balanced props and a balanced bottom.
