I'm a moron..stained my seats! Help. >
Old 05-07-2006, 01:39 PM
TSPM's Avatar
Default Re: I'm a moron..stained my seats! Help.
WHITE GAS....the stuff for camping stoves should do it.
Safe for vinyls.
TSPM is offline
Old 05-07-2006, 01:42 PM
TSPM's Avatar
OH BTW.....check some of the products listed by some of the OSO'ers....make sure they DO NOT CONTAIN CHLORINE BLEACH
TSPM is offline
Old 05-07-2006, 01:50 PM
what is white gas, my friend??
TP121 is offline
Old 05-07-2006, 01:51 PM
Originally Posted by US1 Fountain
I've seen the erasers at our local hardware stores.
Bud and Tar remover?
Yeah..WD-40 and bug/tar remover has crossed my mind.
TP121 is offline
Old 05-07-2006, 02:01 PM
FWIW- I found a mix that works on yellow, or crayon stains, red stains, food satins on white vinyl.
Take 2 parts ammonia, 1 part rubbing alcohol, and 1 part Hydrogen peroxide and spray on stain. cover with saran wrap overnight. Boom...just like new.
Have no idea why it works, but it does. I've taken out 10-11 stains this way on my seats.
Too bad it didn't work on the tar stains.
TP121 is offline
Old 05-07-2006, 08:15 PM
Ted G's Avatar
Magic Erasers are available at grocery stores in the detergent/cleaner aisle. They just use water and work great.
www.cbpba.com
Ted G is offline
Old 05-07-2006, 08:56 PM
Pressurized
performancemary's Avatar
Best thing I found is Laquer Thinner. Only as a last resort bit it goes after almost everything, including the seat , be carefull.
performancemary is offline
Old 05-07-2006, 09:00 PM
offthefront's Avatar
mineral Spirits is ok .... I'm not sure about Lacquer thinner ...
offthefront is offline
Old 05-07-2006, 09:06 PM
'05 Concept SF23
Fast Orange hand cleaner with grit in it . It worked for me where I laid a flywheel on my sun pad. About two good scrubbings and a thourgh rinse and good as new. Joe Murray
f311fr1 is offline
Old 05-07-2006, 09:08 PM
CAP071's Avatar
Grease is 1 thing but when you lay black rubber on white vinyal seats in the sun it's a different story
CAP071 is offline
Quick Reply: I'm a moron..stained my seats! Help.
