Gas milage, 2x454 vs 2x540
Toxic FORMULA
I bought my 272 Formula with t 454/330s and did 1.5 mpg at cruise 3000 rpms and 42 mph with 25 Mirages. Changed to 625 hp 540s and at the same 3000 and 28 Bravos , now get 50 mph and 1.1 mpg at cruise.
If I slowed to 42 mph my mileage may improve. Because no matter what hp you have in a boat , it's still going to take the same number of hp to move the same boat. The bigger engines will be propped higher and turn slower.
I run a 79 30ft scarab with 2 540 pump gas motors. Last summer on the chicago poker run we ran 109 miles and i only used 75gals. My boat is very heavy and most of the time we were running in the high seventies. the boat runs right at 90mph. Thats with 26 pitch quad IV props and the motors spinning at 5800 TRS drives. Brian
Originally Posted by timewarp
Also would it be true that if you had a 500Hp 454 and a 500 Hp 540 both tuned correctly that they would both consume the same amount of fuel at WOT?
Canada Jeff
44
01-06-2008 08:47 AM
