twin engine docking tips?
#51
Buddy of mine has a Formula 350 SS with Bravo III's. It has Axius so 99.9% of the time you are using the joystick to dock it. A couple of years ago just for shats and giggles I backed it using the shifters up to the outside of a friend's dock. I really didn't notice much difference in how it reacted compared to Bravo I's. You would really need to manuver two identical boats, other than the drives, to know for sure.
#53
Has anyone ever docked a v hull with twin i/o in a tight spot like this guy ? Post your videos. http://youtu.be/W36rDKl4T5s @1:10.
#54
I taught boat handling for 6 years included in the mix were some nasty powered ones, most I/O's tend to have the engines set to close for good up close maneuvering and are usually far better off docking on one engine. Try one engine docking and you will see little to no difference using either engine, the plus is you will get into less trouble as things happen in a more manageable fashion. I/O boats will always go in the direction the drive is turned steering works better then shifting. For one reason or another most boats have one engine that never dies and one that can be finicky, I always told my clients do your docking with the finicky one, if it craps out there is -0- panic simply grab the reliable ones shifter and finish docking. Using that practice has stood well by many of my customers over the years, try it many will find it may make your life easier.
Phil
Phil
#55
Member #9
Member of the Liquid Jungle
#57
We were presented with a similar situation when we visited my brother-in-law. Never had twins before, but his advice was basically get it to open water on the lake with no other traffic and get a feel for slowly turning in place, side docking, forward docking, etc. Just practice going slowly driving a bulldozer/tank, and you'll be fine. Worked for us.
#58
Ginger or Mary Ann?
Several of my dock buddies have cruisers with twins B3's. Night and day difference handling/ docking from us with twin B1's or Alphas. So much better.
#59
Good to hear, looking at a formula 28ss and it has B3's. Have experience with single and twin Bravos but wondered if the B3's pivoted better, and tracked straighter or worse. Sounds like better which is great news. Thanks
#60
Someone once told me to "drive it like a BobCat" Problem is.....I never drove a Bob Cat!
But that did help me to understand what the boat will do when shifting back and forth with port and starboard motors/drives.
I still find most of the time best just to use both motors/drives and the wheel. If in tight quarters I do know how to spin a 360.
