Who makes the best 12V oil changer?
Re: Who makes the best 12V oil changer?
Originally Posted by DRIVEN1
Thanks for the info. I am leaning towards buying the one from West Marine. One of the main reasons being they have always been good to me if I need to return something that is broken.
1 Post
No hose mounted. I was going to go thru the dipstick.
Originally Posted by cig1988
Definetly go with the the hose attachment on the drain plug. Saves alot of time and drains more than going thru the dipstick.
Does is just screw right into the drain plug? Do you leave attached when not using it? If so I guess I would need to buy 2 more attachments.
Yup, screws into the bottom of the oil pan and the hose is permanent. As usual heat up engine prior to removing oil and takes about 30 seconds to suck out. 1 per engine.
Chris G.
Chris G.
1 Post
It replaces the drain plug permanently & routes by the intake/valve cover. Has a brass plug on the end of it. If you decide to do it this way get about 4' of reinforced hose, the type that is used for fresh water system. Attach it from the hose to the pump & your set. After the change while removing the reinforced hose from the brass end of the oil hose jam a peice of paper towell to avoid leak out.
1 Post
Thank you for helpfull tips.
Anytime. It will drain much better than the dip-stick. The drain plug is at the lowest point of the pan.
Just thinking out loud. How hard is it going to be to get the drain plug on the back motors?
