Merc 525 Oil Change
Old 07-10-2006, 07:30 PM
Default Merc 525 Oil Change
Can anyone tell me if the Mercury Racing 525 (or any other Mercury Racing I/O) engine has an oil drain hose as OEM standard equipment (similar to the Ilmor pictured) or if one must change the oil the old fashioned way by removing the drain plug in the oil pan? Pictures are welcome & greatly appreciated.
NASCAT is offline
Old 07-10-2006, 07:56 PM
AKA NoMoBoatin
Default Re: Merc 525 Oil Change
Pump it out through the dipstick hole.The good pump is about $200.I have them on my 525efi's and they leak at the swivel 90 attached to the bottom of the oil pan.
docmanrich37 is offline
Old 07-10-2006, 07:57 PM
Forum Regulator
Sydwayz's Avatar
Received 1,249 Likes on 542 Posts
525EFI and the 496 varieties come with the Oil Drain hose factory installed. The 600SCi probably has one as well.
Sydwayz is offline
Old 07-10-2006, 08:48 PM
pm203's Avatar
Yes, it,s connected to the bottom of the oilpan and pumps out pretty easily.
pm203 is offline
Old 07-10-2006, 08:54 PM
Smitty's Avatar
West Marine has a slick oil removal pump that literally sucks the oil out thru the dipstick. You pump about 8 times and watch it draw out the oil. It has an automatic shutoff when full. I love mine. it was around 90.00.
Check it out.
Smitty
Smitty is offline
Old 07-10-2006, 09:33 PM
Steamin Rice's Avatar
My 525 EFIs have the oil drain hose factory installed.. My boat builder attached these to plugs in the transom so that I can drain the oil from outside the boat. Makes it really easy
Steamin Rice is offline
Old 07-10-2006, 09:47 PM
cosmic12's Avatar
my 525 also has the hose that comes out the hull plug hole. works great just put it in a jug and walk away.
cosmic12 is offline
Old 07-10-2006, 09:59 PM
Thanks for the info guys. Can anyone tell me what is is on the end of the hose? The Ilmor has a brass -6 female flare hose end w/ a -6 brass plug in it. I have put together an Ilmor Oil change kit that I'm going to make available to others but wanted to see if I could offer more than 1 application increasing the value & versatility instead of offering 2 kits. One kit w/ the neccesary fittings to accommodate Ilmor & Mercury Racing applications.
I'm embarrased to have had to even start this thread w/ as many 525's I've looked at over the years but I've never owned one nor looked close enough to really know. I was hoping to get by the Extreme Marine this weekend & never made it. They have several DCB's & Fountains w/ the Merc packages.
NASCAT is offline
Old 07-11-2006, 07:19 AM
gsmith9898's Avatar
I have the 525efi and I have not found the drain hose. How long is it and where do they tie it up?
gsmith9898 is offline
Old 07-11-2006, 07:47 AM
Dave M's Avatar
On the 496's the hose is about 3 feet long. You can see it coming out of the pan in this picture. The other end stays clipped up near the intake. I guess you can clip it anywhere you want.
Dave M is offline
Quick Reply: Merc 525 Oil Change
