Questions about the Mercury Racing 525 >
Old 04-20-2012, 11:02 AM
Originally Posted by Mbam
Mecury has a seperate division for the remanufacturing. They are the ones that make the 383 and 357 engines and the rest of the Mercury reman & CPO stuff. The remanufactured 525 longblocks come from them. So --- done by part of Mercury but not done by Mercury racing. Like most of the consumer product they have a 1 year factory warranty.
bam are the long blocks sealed also
TWIN-SPINS is offline
Old 04-20-2012, 11:18 AM
BRUCE SEROFF's Avatar
when Merc rebuilds your 525, they give you all the old parts back
BRUCE SEROFF is offline
Old 04-20-2012, 11:55 AM
Dean Ferry's Avatar
I've seen waterslinger's 525 head, it's brand new. Here are some pics.
Attached Thumbnails Questions about the Mercury Racing 525-photo.jpg   Questions about the Mercury Racing 525-rh2.jpg   Questions about the Mercury Racing 525-rh3.jpg
Questions about the Mercury Racing 525-rh6.jpg   Questions about the Mercury Racing 525-rh5.jpg
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 04-20-2012, 06:03 PM
Originally Posted by Dean Ferry
s30,
Can you elaberate on the "4 top exhaust bolts were moved back about 3/8th's of an inch.heads can be drilled and tapped for a stand bbc pattern" What exhaust did you use after this mod? Do you have any pics you could post?
Thanks,
Dean
I'm bringing the gasket(525efi) home to take a pic of it.The standard bbc upper bolt holes are marked on it to show difference.The bottom holes are the same.
For exhaust i'll be using gils.
sutphen 30 is online now
Old 04-21-2012, 07:09 AM
Dean Ferry's Avatar
S30,
Thanks for the great info, can't wait to see the pic. I'm going to get with Waterslinger this weekend, hopefully, and look at his 525 head and bring a pair of the KE headers I have and compare them to bolt hole pattern on the head. Need to do this BEFORE he sells it!
Old 04-21-2012, 11:47 AM
Wink
My suggestion, just buy the Dart 525efi replacemnt head and have Dart do standard bbc exhaust holes and locations and you'll end up with a better flowing head out of the box. Raylar has done a lot of testing, research and cnc'ing upgrade work on the Merc/Edlebrock HP525efi head for our Raylar HP675efi engine and believe me it was a "booger" to get this stock head to flow what we needed. We ended up with over 405 [email protected] lift on the intake and [email protected] on the exhaust with some good "black art" rework. "most things are possible, it just takes a little more time, effort and money"
Best Regards,
Ray @ Raylar
Raylar is offline
Old 04-21-2012, 12:48 PM
Offshoreonly Advertiser
Mbam's Avatar
I doubt if the long block from Reman is sealed. I'm not sure that program in still alive. Anybody know? I can find out Monday.
Mbam is offline
Old 04-21-2012, 05:07 PM
Whipple Charged's Avatar
Originally Posted by smiklos@sunprint
Dustin
Have you tried Dart's head with Mercury 525/600/700 Header and coolant flanges?
Steve
Well they are just Dart Pro 1's with the material added to the front for the water system and the exhaust flanges changed. So we've run many Pro 1's with plenty of success and offer far more potential than the stock heads. I'm not a big fan of "as cast" in general so the CNC finished versions are a good upgrade.
Whipple Charged is offline
Old 04-21-2012, 09:44 PM
Thanks!
Steve
smiklos@sunprint is offline
Old 04-22-2012, 08:29 AM
isn't the exhaust stud pattern same as 496?
pqjack is offline
Quick Reply: Questions about the Mercury Racing 525
