Best drive 800hp Cat- ASD-7 or Konrad 540?
Re: Best drive 800hp Cat- ASD-7 or Konrad 540?
Found this for you.
Rik
arneson-industries.com
Posts: 514 Re: ASD 7's Rik whats the scoop?
The ASD7 differs from the ASD6 with a stronger case, an improved steering system, bigger internals, and a different rudder configuraiton.
These changes have allowed us to raise the power level for the ASD7 to 850 hp.
Rik
Wiggler, My buddy did a recent conversion to the Konrads on a 42 Sonic. They have been working great, and the customer service is good also. Always available for qustions, you won't need them for problems. Good Luck
ASD7 M Drive Unit
Right Hand Rotation
Left Hand Rotation
Reduction/Overdrive
1:1
1:1
1.32:1
1.32:1
1.56:
1.56:1
Transmission
Velvet Drive
Kit Unit Weight
320 lbs
OAL
52”
Steering Angle
40 Degrees
Trim Angle
17 Degrees
Maximum Input Torque
850 lbs
850 lbs
Right Hand Rotation
Left Hand Rotation
Reduction/Overdrive
1:1
1:1
1.32:1
1.32:1
1.56:
1.56:1
Transmission
Velvet Drive
Kit Unit Weight
320 lbs
OAL
52”
Steering Angle
40 Degrees
Trim Angle
17 Degrees
850 lbs
850 lbs
Originally Posted by customryder
Arneson's!!! I can put to bed all the nonsense about docking backing, turning, etc that is all BS...my 36 Nor-Tech Cat has 0 porpoise at any speed & handles like its on rails. it come on plane flat with no trim tabs or tucking the drives way down, just hit the throttles & go...anyone is welcome to come take a ride in mine if you wish.... + they will not break Period... The public is so mind set ... driven by mercury.. most are afraid of change..
Can you post some pics of your finished ride? Yours is EXACLT how i want to set up my 36. I have one of the rare non-notched NT's so its almost begging for the ASD conversion.
-Rick
custom, wont get a ticket shootout weekend, I think you have a nice setup on your 36, do you have the asd6 or 7,hope to see you at shootout, jim
