Aronow 24' Cat?
Re: Aronow 24' Cat?
I took a spin in one back in 89' at the Aronow facility on Gasoline alley. The boat had Twin V8 Johnsons on it. I don't think they made a lot of them. I have some old pics of the boat somewhere. I will try to dig them up.
Re: Aronow 24' Cat?
topspin80 and ktron thanks for the info. I'll put some pic's up.Had the boat out about 10 times and was trying to workout a bucking type problem at about 50-75mph,any ideas?
Re: Aronow 24' Cat?
I don't have much cat experience but it sounds like the tunnel is starting to get packed with air to create lift but then releases a little giving the boat a hopping sensation. Some cats do this at similar speeds.
Do you have tabs on the boat?
Re: Aronow 24' Cat?
ktron is correct.
Im not familiar with your hull but must full tunnel hulls will "lope" at a certain speed. It is the transition point where the hull is packing air but not enough to support its self. The most common fix is to not operate the boat in that window or use a tunnel tab. Tunnel tabs have a downside so do your homework before you decide that you want to go that route.
Post some pics and details of your set-up.
Re: Aronow 24' Cat?
Tantrum and ktron, thats exactly what the boat does and I installed a temporary tab that is adjustable but not while your driving, so it has a downfall of not being able to come up at speed. haven't got to try it. Was thinking of re-rigging with a pair of Yamaha's, 250's, or 225's vmax's for more reliablity? Will put pictures but haven't figured out how yet?
1 Post
Re: Aronow 24' Cat?
I had one in 1994 or 95. I traded it in on a 45 Sonic in Minniapolis in 96. Fun boat did around 90 with 2 2.4 merc's. I still have the dual foot pedal and mini swim platform in box that I never put on. I bought it from Copeland jr.and it had Copelands on boat.
Re: Aronow 24' Cat?
damdonzi, mine is a 24' slightly smaller and lower profile. cool brochure,I searched all over trying to find some literature. I did find the ad for the exact boat but you could only read the headline.
