Drive Actuator Help
Are the actuators attached to the drives in thepicture Mercury? If so, does anybody know the procedure to attach the cable into the actuator?
Take the nut off the front of the tube. There is a "C" shaped washer under it. Slide the notch of the Morse cable into the notch in the C washer. Screw the tube nut back on. That's it.....
