step hull
#61
Re: step hull
As I recall, George Linder told me that you did not test the aeration on that set-up. In case that is true I will attempt to recall the effect,
The step on the Challenger was a different idea, it was a small step, almost a notch that only existed between the two inside strakes. It did not extend to the outer edge of the hull. The problem seemed to be that the water around that step set-up sealed off the ability for the air to be draw in and 'release' the low pressure area created. The boat was stuck down until a wave or some 'release occurred. The solution was to allow air, via a pipe, to release the negative pressure and therefore release the boat.
I have had the same experience with a shallow notch holding on while coming on plane. Again piping in a release opportunity for air solved the problem.
#62
1 Post
Re: step hull
The fact that the name of that picture is "Stinson Splash" just made me fall out of my chair. Has anyone heared from him? That crash may have had more to do with He and Dick arguing at each other rather than running the boat. Best race footage I ever saw in my life was a deckshot of Sean and Dick running F-2. They kept yelling at each other and at one point Dick got SO mad he actually stopped looking at where he was going and looked over at Sean for about 5 secounds. Kinda like a father getting ready to slap his kid accross the front seat. What ever happened to the good ol days of racing?
#63
Allergic to Nonsense
Re: step hull
Originally Posted by TUFFboat
Now I'm just checking here, T2x,
When you built the Challenger 21 with the step in it... remember... do you recall that it went better with or without aeration tubes in it?
I remember the difference.
My belief is that pads and steps are not a good combo....
T2x
