New Mystic 50' cat at LOTO
#31
A to Z
Originally Posted by Dean Ferry
It is if the hull isn't designed to handle 5000+ HP! In fact, as far I know, (Although I don't know as much as Sean H does,
) I don't know of any manufacturer, other than Callan/Mystic, that DOES run 5000+ HP in their boats?
I'm talking racing/recreational, high performance hulls, not battleships or some other SHIP!? ![Evil](/forums/images/smilies/evilB.gif)
![Drink](/forums/images/smilies/drink.gif)
#32
Originally Posted by Sean H
um, what is this? ![Drink](/forums/images/smilies/drink.gif)
The Bat boat!
![EEK!](/forums/images/smilies/eek.gif)
Dean
Everything is for sale @ a certain $$
#34
As far as boats with 5000+ hp, you might want to check out Mr. Scott's new MTI, I believe he and MTI will fall into that catagory.
Also No Tech has several boats out that have over 5000hp.
I think there also some 4 engine Skater that are about that hp also, ie Big Thunder.
#36
[QUOTE=42MTI]I think the idea of how much horsepower a hull can handle is only a byproduct of how the boat will respond at a given speed. Since all boats don't run the same speed with the same horsepower.
Very true, you can strap blower motor to a 2x4 and it will fly! BUT, if the hull is designed from the outset, with a target top end speed and horsepower in mind, then it's a safe bet that the hull will handle it, in all types of water conditions. I looked real close @ DS's turbine MTI @ LOTO, and it's an awesome looking rig, and I hope they attain the speeds they are looking for.
Dean
Dean
#37
I hope so as well, MTI has an unbelieveale amount of R&D time in that hull. There are many, many things you can't see that they have done to try and make sure it is stable at the target speeds.
I know David has to be excited as hard as he has worked on it and as long as he has had to wait for it. I just hope everything works out as planned. We should know soon.
#39
Originally Posted by Brad Zastrow
What about resale value later? One off boats no matter how well built can be difficult to sell. MTI 1st choice and Skater 2nd.
#40
As far as boats with 5000+ hp, you might want to check out Mr. Scott's new MTI, I believe he and MTI will fall into that catagory.![Big Grin](/forums/images/smilies/biggrin.gif)
AMF's new Mystic C-50 is slated for 7400hp.
4 x T53- 703's 1850 HP per (weight 550lb each)
Marc
