496's vs 500 EFI's
Thanks for the tip Ray, I've never rode in one . I was considering it mostly from a looks point of view ,and having owned three Donzi's to date,but I certainly will take your advice and test one before purchase!!! Are all 500 efi's raw water cooled ????
![EEK!](/forums/images/smilies/eek.gif)
The 500EFI is standard with raw water cooling, what ever you run in gets circulated throught the engine and exits the exhaust.
the 496 is closed cooled meaning the raw water comes in and passes through a heat exchange (big black thing on front of engine) then it passes thru and out the exhaust. The engine block itself has coolant inside and isolated from the raw water. Similar to a automobile whereas the coolant is cooled by a radiator but saltwater is sill going throught the heat exchange and exhaust. The exhaust area seems to be the most effected bacasue of the high tempratures and salt mixture. These if they fail will take out your motor. They need to be flushed every time.
You can get closed cooling put on the 500's maybe 1K each. but you still need to flush to protect the drives exhaust and heat exchanger.
Ray
Ray
JC Performance Engines
A wise old man once told me that you will burn out your motors before the salt corrodes them, if they are properly taken care of. No need for fresh water cooling.
Registered User
1 Post
If this is a cruiser, go 496 duo,
However take Raypanics advise, drive it first and see if it has enough performance for you, sounds like they are pretty slow.
WILL
![Drink](/forums/images/smilies/drink.gif)
WILL
Originally Posted by Montauk Crossbow
I am looking at the Donzi 39 ZSC ,Its more of a performance cruiser than a GO FAST ,are the 500 efi,only salt water cooled? Is there a problem with these motors in salt ,I've always had saltwater cooled 454 's and never had a problem !! any info would help in my choice Thanks
The 39 that Ray rode in was definitely not running properly...some of those boats had the PWC lift extension added onto the back of swim platform, too; which is a huge performance-kill. That boat with 500EFI's should run into the 50's any day. We have customers owning examples of both power plants in that hull, and the truth is that there's not that great a difference in top speed. You will get a little higher cruise speed with the 500's, though. Having said that, Merc has made a BIII XR drive to handle the torque of the blue motors.
Hugh
Hugh
