Verado 300 and 325HP to debut in Miami
#42
mercury service manual says to change oil every 100 hrs more so if the engine is used under adverse conditions.
requires 7 of a 92-883722k01, 4stk oil qt @ $7.00 per for $50.00 in oil plus 1 of a 35-883701 l6 verado oil filter @ $20.50 now were at $70.00 plus labor. so well say $100 for the oil change plus the down time. or you go with optimax or etec oil @ $20.00 a gal. may be 5 gal every 100 hours tough choice.
By the way, where is the oil drail hole on the Verado's ??? Is it servicable while the boat is water ?
#44
ECM's dont lie.. Neither do the product id/S/N plates.. Those are 275's as is the 300 in the booth..
#45
Guys ... there are plenty of "test mules" runnin around on Grady Whites and Contenders down there right now ... The Outboard wars are really starting to heat up ! BUT , a little patience will go a long way here , as AVAILABILTY may be a bit down the road on some of this stuff ... especially of concern are the lower units holding up ... but they're getting there .....
#46
Also you do not have to use the Mercury oil. Most all the SKA guys with Verado's are using Mobil 1 which is less than the Merc stuff.
Part of the what makes the Verado's good is the whole package as a system. The throttles and steering are car like, easy to use and work, no cable to worry about and very very reliable.
#47
[QUOTE=marylandmark;2029340]Good eye there Scott B. You would think a company the size of Merc could have done a better job perpetrating a 300. They are in bed with Reggie right?
(ps- I like beakers; just stirring the pot as it is 17 degrees in MD...
Actually the banner over the Fountain both in Miami read "Fountain Mercury"
![Cool](/forums/images/smilies/cool.gif)
![Drink](/forums/images/smilies/drink.gif)
#48
Charter Member #415
I notice Merc is introducing a new 200 hp 4 cylinder Verado and will still have the 200hp 6 cylinder Verado. Seems a little strange. I guess lighter weight is the goal,but to get the same horsepower rating with 4 cylinders instead of 6, wouldn't they have to turn the boost way up? Looks like the 4 cyl 200 would be highly stressed,or maybe the 6 cyl 200 is low stressed.
#49
The 4 cyl 200 is a pretty interesing package.. All of the 4 strokes are overweight, it's good to see Merc is working on solutions.. I didnt look at the ECM on the display one though, maybe it's really a 125??
![Smilie](/forums/images/smilies/smile.gif)
Yes, there are test mules down here, seen a few already. Merc 300 will not be available until August, the Yammie 350's are suposedly in the warehouse now and ready to ship...
