Best oil
Re: Best oil
Ask Tyler what he reccomends... I use 15-50 M1 and In general I would say you cant go wrong with it, the 20-50 V-twin seems to be popular also but is on the expensive side at 7+ / quart..
Re: Best oil
He recomened the Mobil 1 15/50- I didnt ask but I would assume its a sunthetic - I Just want the input form all you other boaters to see if its a good choice.
Registered User
Re: Best oil
Mobil 1 goes in everything I own.
I have a shop truck that just turned 400K. '96 350 Chev. Never as much as had the valve cover off of it. Uses about a quart in 5K. I change every 10K.
Re: Best oil
Rotella T 15-40 in flat tappet boat engines and 2006 PSD. I had trouble with cams before this when running M1 15-50. This will now be the third season with these engines and running rotella. If you have oil temps that exceed 250f as an upper limit, use the synthetic rotella.
BT
BT
JGB
21
02-08-2011 11:24 AM
jeff32
06-28-2006 08:48 AM
FlyFast
13
05-10-2004 11:39 PM
