Shrink Wrapping for Shipping
Offshore Cowboy
Never heard that one. Also that is is problem because it moves around under the shrink wrap also creating a rubbing motion on the paint or gel surface. That will dull or scratch as well....BUBBLE WRAP IS NOT A GOOD IDEA. The Film is a static adhere and is designed to withstand the 300,000 BTW of a shrink wrap gun. Bubble wrap would also melt under the heat creating a HUGE mess. Also as mentioned above Tape method as sealing ONLY....NO STRING JOBS
If its done correctly that should not happen...you get what you pay for. All NEW boats we get in for stock are done by the MFG and are perfect upon arrival. The use of quality ANTI CHAFFING film under the shrink wrap is the key. Also the boat must be spotless clean before wrap so nothing between the hull and the wrap act as sandpaper to the finish. It is basically the same film new cars come with on the top and side surfaces. Now this film is somewhat costly and is an additional step in the wrap process so its more time and materials.
Yes they do......shipping cross country to us it must be done correctly to avoid damages and scuffed gelcoat. The multi temperature changes as the product moves cross country makes the shrink wrap expand (heat) and contract (cold) over and over acting like a sander on the finish. Without the anti chaffing film several areas would need to be re buffed with a finishing compound.
Sea Ray uses bubble wrap..... it works fine.
Most issues have been coverd, but a real big issue is to MAKE SURE the entire parimiter of the shrink is taped. When traviling dust and dirt can and will make it up the sides and nomater what you have on the hull to prevent chafing, some will occur unless it is sealed ( you should vet it at the top )
I have probably done 2-3000 boats and learned most of the do's and don'ts
RT
RT
Sea Ray finishes are not in the same league as most high performance boat finishes which can be like a mirror. You would not notice micro fine scratches on a Sea Ray where you would easily notice them on a highly buffed finish.
