Merc 575 Question...
Old 03-28-2007, 07:46 PM
bmanafort's Avatar
I had a pair of 575's in my fountain and they were a great pair of motors.
bmanafort is offline
Old 03-28-2007, 09:21 PM
JC Performance Engines
Stormrider's Avatar
nice to see her coming home so soon johnny.
my suggestion... buy a 2nd pair of blowers, so when/if these go, you're not outta commission too long. and always have 1 backup set.
Stormrider is offline
Old 03-28-2007, 10:01 PM
Originally Posted by JOHNNYD454
Pwrbt33.....first off thanks......so your saying there is no preventitive maintenance that I can do to the rear side bearing except a rebuild before something happens.........and only an oil changes to the front side.
Those look like the Wiand blowers ( the later were B&M's)
The Wiands have a "W" cast in the front housing.
Mine have the Wiands, and they have oil in the rear.
I ended up removing the superchargers to change the oil.
It's not that big of a deal to do.
They don't hold much oil in either end.
The only problem I had with either of mine was
a small oil leak at the shaft seal, and that was an easy fix
also.
Great engines
I'm shure you'll enjoy them
JaayTeee is offline
Old 03-29-2007, 04:26 AM
Rob......I have already been in touch with the Blower shop about a backup pair....the snout seems to be the only problem for getting a backup but they are working on it....and yes she should be at her new home soon.......
JayTee......that is what I thought from all of the researching I have done on OSO........is there any way to suck the oil out or is removing the Blower the only way....
Here's Johnny is offline
Old 03-29-2007, 08:29 AM
OSO Moderator
BillR's Avatar
At 200 hours you should be fine.
Mine were rebuilt @ 290 hours and they looked fine. 20/20 hindsight, I could have gotten away FINE w/ changing valve springs.
Also had Blowershop rebuild and upgrade blowers About $2K for both.
Great motor! Reliable and fast. Check the front thermostat housing - esp where the hoses connect. They like to corrode there and close up the passage.
Do a search here and on Speedwake for 575SCi or just 575. Lots of good info!!!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 03-29-2007, 11:14 AM
I have early production 575SCi's.
There is oil reservoirs front and back. I watch them
like a hawk and change the Merc drive oil in them
yearly.
At 430 hours and 5 years I've just completed a head
overhaul on one engine (tired exhaust valves). And
the head gaskets suck although I never had a failure
due to them.
Watch the diaphragm fuel pump on the raw water
pump like a hawk too. Especially every year take it
off and change the oil in the little reservoir.
But what do I know. I'm not a marine mechanic.
Pesky Varmint.
Pesky Varmint is offline
Old 03-29-2007, 05:14 PM
Thanks for all the great tips guys........
Old 03-29-2007, 05:41 PM
I hate the winter!!
Vinny P's Avatar
We are going to be busy this year.....
Vinny P is offline
Old 03-29-2007, 05:46 PM
Old 03-30-2007, 10:09 AM
I have a pair of 2002 575's and here's my advise (for whatever it is worth). I had a blower fail last year at 250 hours. I don't run my boat real hard, but I do lean on it. I bought the boat new and have changed the oil in the blowers annually. By the time I could hear the rotors colliding, it was too late. They were bent and I had to fork over $3500 to the blower shop for a rebuilt blower because no one makes rotors any more. Mine are Weiand. Now at 280 hours I just had a head gasket fail. I love the motors but highly recommend you rebuild your blower every 200 hours or less! The cost is $400 from the blower shop compared to $3500!
Quaid24 is offline
Quick Reply: Merc 575 Question...
