Fuel reserve estimation.  Any tricks? >
Old 04-17-2007, 12:07 PM
Sonic30ss's Avatar
Wink
Originally Posted by Dave M
Forget about your gas guage.
I use my hour meter. Fill up tank, go boating. Next time fill up again, divide gallons by hours to determine rough estimate of galllons per hour.
I've done this over several years and always have pretty consistant GPH. When i go to the gas station I can usually tell within 5 gallons how much it will take to fill.
I use the same method, works every time.....except at a poker run, then the gph is all screwed up....can't figure out why
Sonic30ss is offline
Old 04-17-2007, 12:26 PM
Neno the mind boggler
glassdave's Avatar
Originally Posted by CAVelocity
I have found with my 500EFI, that I consistently get a little better than 2 mpg, almost irregardless of cruise speed. My Garmin GPS has a built in trip odometer, so each time I fill up my 80 gal tank, I reset the trip odometer and know that I have 160 miles before I am completely out. This has worked out great for me. I have done Homestead to Key West a few times without filling up..... 150 miles via the inside passage.... and then put a little over 70 gals in.
This may not work as well with carburated motors, but it sure seems to work well for me.
same here. i track my fuel with my GPS and my average consumption that i established the previouys year. works pretty well. i also have flo-scans from Navman that work pretty well to but i prefer the GPS method.
08 OPA High Points Champion
glassdave is offline
Old 04-17-2007, 12:43 PM
full tank on gauge= it aint full
3/4 on gauge=1/2 tank
1/2 tank on gauge =1/4 tank
1/4 on gauge= u better be near the fuel dock or have seatows number ready
dreamer is offline
Old 04-17-2007, 01:17 PM
dukenrock's Avatar
Floscan
dukenrock is offline
Old 04-17-2007, 01:19 PM
Originally Posted by wrasse
My 24ft donzi's fuel gauge is nortoriously inaccurate and my understanding is that most boat's are. I believe my tank holds around 80gals. I've been too chicken to going anywhere far on the water due to fear of running out of gas. Instead, I do one day cruises around my lake and fuel up each time I go out. But I really want to go exploring places further away and be confident in how much fuel I have left.
Any suggestions?
If you can get to the tank it will be stamped/stickered with its size so you will atleast know what is in the boat when it is full. My tank is viewable from under the back seat.
Jupiter Sunsation is offline
Old 04-18-2007, 09:13 AM
GLH
GLH's Avatar
Any suggestions?
Kanookstr & JS have the solution...
GLH is offline
Anarchy Powerboats
Magnum Marine
3
08-16-2006 01:05 PM
bford1
11-06-2004 07:35 PM
timucin
2
11-28-2002 01:17 PM
Ratchet
11-11-2002 06:03 PM
timucin
12
11-09-2002 09:51 PM
Quick Reply: Fuel reserve estimation. Any tricks?
