Boat Documentation Question
The name and hailing port need to be 4" The fine is $10,000. I would not chance going out without the name. The numbers need to be permanently mounted in the boat as to cause damage if removed. I just went through this. I am using some temporary vinyl lettering for the name until my grapihics come in. The numbers can be 3" and clear painted/resined over to make them permanent in the bilge area.
Were doomed!
You can see them in the back of the picture of the motors....the color difference is the resin ontop of the numbers...
-Wally
-Wally
My boat is CG documented and registered in Texas.
So I need:
1. Name and hailing port in 4 inch on the back of the boat.
2. State sticker on outside of boat (no numbers)
3. CG #s inside the bilge with a clear over them of some kind.
I do not need the state numbers on the outside of boat?
Since I am registered in TX as well, do I need the ID # inside the bilge?
ok... let me make sure I am straight on mine.
So I need:
So I need:
Were doomed!
that is true..ive seen the numbers inside the cockpit before...
-Wally
-Wally
I survey boats all the time down here where the owner ONLY has the document on board. The numbers in the engine room are easy to install. I doubt the officer is going to fine you $10,000 when he can see you just recently received your papers by the post mark. Most high performance boats have so much going on at the transom; outdrives, external steering, exhaust outlets/mufflers, K-planes, etc., that the Marine Patrol guys will understand that the name and hailing port is not practical to be on the transom.
If you get stopped, just be courteous and show your paperwork. Unless the guy's a real pri--, you'll be just fine.
The name and port don't have to be on the transom.
The official number assigned to documented vessels, preceded of the abbreviation "NO." must be marked in block-type Arabic numerals at least three inches high on some clearly visible interior structural part of the hull. The number must be permanently affixed so that alteration, removal, or replacement would be obvious and cause some scarring or damage to the surrounding hull area.
The name and hailing port of a recreational vessel must be marked together on some clearly visible exterior part of the hull. All markings may be made by any means and materials that result in durable markings and must be at least four inches in height, made in clearly legible letters of the Latin alphabet or Arabic or Roman numerals. The "hailing port" must include both a place and a State, Territory, or possession of in the United States. The state may be abbreviated.
Hey, now you've just got to buy another boat so you can apply your knowledge!
