Trim and Tabs "popping" through the speakers.
Charter Member #232
Make sure your ground for the amp and the radio go directly to the battery and are grounded together. If you want drop me a line and I will help ya out. Could be a bad RCA wire as well. Seen that a few times. You should be carefull as you can blow the amp and speakers if you get a bad enough pop.
Jon
Jon
Put your best foot forward!
Thanks Jon, I have done several systems in the past (myself from scratch) and never had an issue - but somone else did this one and, well... And if I do blow the amp, no worries as I have better stuff I may replace it with anyway, so we'll see. But thanks for the offer - if I get stuck your phone might be ringin'!
zimm17
3
03-13-2007 05:23 PM
