boat sitting in salt water
I have done it for five days when I took it out bottom was clean.but I used it everyday I think thats the key also brushing the bottom like someone else stated is also a good idea.you could anchor in some shallow water and do that.Bottom line we have these boats to have fun with.This trip sounds like it will be that enjoy
wow, went to my boys baseball game and boom 2 pages. You gota love OSO.
OK, your right, I will take the boat and do the trailer thing. I can't go down to the good water and not bring the pride and joy I just worry about where to store it, but i'll figure out something (safe)
I'm sure I can find a place to hook up a hose and flush and all that good stuff. But how do I use the salt away w/ the hose.
I'm fresh water and never used it before.
The house I grew up in was on the beach (pacific) and kept both a 22 Whaler Cuddy and Sea Ray all summer on a buoy in front..... The nice thing though was low tide created a mud flat, so could run a hose for daily fresh water cleaning and flush engine.. Plus both got used daily. Several of our neighbors did the same. Salt water is only evil if you let it...
A week would run fresh water hose down after each use, salt dried plus heat on any metal surface will F' them up. Other than you should be more than fine. Plus flush engine's when it comes out....
A lot depends on the water temperature, and how much water flow is in the place you have it in the water, and if you use it during that time. Once I had a boat in a wet slip while I was doing some work on the trailer. CigDaze will be familiar where it is, it was at Huber Yacht during the middle of summer. There is practically no water flow there, because it's at the very end of a canal. I had the boat there for about four days, when my brother and I decided to go fishing. I couldn't get the boat on a plane. I thought I had spun a prop. Turns out there were barnacles that were already over a half inch long growing on the hull, and any part of the drive that was in the water. The led to several hours of "good clean fun" with a scraper, and muriatic acid.
This is not conjecture, or other advice from our northern friends, but actual real life experience. It may be different if you run it everyday, I've left boats in the water overnight, and just the stray current from other boats in the marina made my drives show the beginings of electrolisis.
Where are you planning on leaving it in the water?
Speaking of barnicles,
In the northeast, you will start to see the beginnings of barnicles after two weeks. At this stage, they can be power washed off. If you go any longer, it will get alot tougher. I can't believe how fast they take hold in Fl.
