Charlyn helm part # ???
Old 01-10-2002, 03:56 PM
blown formula's Avatar
Question Charlyn helm part # ???
Does anyone know the Charlyn part # for the hydraulic helm required for a single cylinder Marine Machine steering set up? Everyone (cpperformance, wpm, etc) seem to have only there own part #s and are not sharing the charlyn #. I have a guy wanting to sell me a helm, but I want to be sure it is the correct size first.
....I want to prevent a "bad experience !.
blown formula is offline
Old 01-10-2002, 04:28 PM
Katdrvr's Avatar
Post
Try this. http://www.eatonhydraulics.com/cds/products.htm
I have been looking at the series 2 or the Flex 4.
I think with the single cylinder you only need about 60cc volume. The more volume the helm has the easier it is to turn the wheel.
mike
Katdrvr is offline
Old 01-10-2002, 05:13 PM
Post
Katdrvr, thanks a bunch !! I will now know what I am looking at. That site is perfect.
Old 01-10-2002, 05:26 PM
rws
rws's Avatar
Post
Here is the Char-lyn Steering Control Unit (helm) that I used on a Marine Machine single cyl. setup. ( 3-series 211-1001 )4.5 cu. displacement per revolution.
Rob
rws is offline
Old 01-10-2002, 05:52 PM
Charter Member #927
Payton's Avatar
Post
Check out Northerntool.com
Last winter I used their 201652-c159 model helm. Rated at 100 cu.cm . The 80 cu.cm would have worked but needed to be back ordered. The price in last years catalog is $270. They also have a steering column for $45.
Just be sure you buy an open center system. I bought one from a guy on the board last winter it was a closed center and didn't work at all. There was no flow of oil to the cooler when I wasn't tuning the steering wheel.
Good luck!
Mark
[ 01-10-2002: Message edited by: Payton ]
Payton is offline
Old 01-10-2002, 05:56 PM
Charter Member #927
Payton's Avatar
Post
to compare apples to apples:
the 80cu.cm is 4.8
the 100cu.cm is 6.0
and is 1$ diff in price
These are Danfoss, I believe they make Char-lynn
Payton is offline
Old 01-10-2002, 06:59 PM
Charter Member #601
Mr Gadgets's Avatar
Post
Katdrvr
Dont you mean the smaller the displacement of the helm the easier it will turn.. and more turns lock to lock?? That is what I have found to be correct. If I am wrong I would like to be corrected....thanks.
I know I had to go to a smaller helm with my WPM steering to make it turn easier..
Dick
Mr Gadgets is offline
Old 01-10-2002, 07:32 PM
Member #2 ....Jeeezz
cigarette1's Avatar
Post
Imco has a lot of info for hydraulic steering. Here is a link to there helm units.
http://www.imcomarine.com/stern/7.html
[ 01-10-2002: Message edited by: Cigarette 1 **** Original Member ]
cigarette1 is offline
Old 01-14-2002, 10:43 AM
Post
Payton !
Since you used a Northern tool catalog helm....is it possible to also use a 12 volt hydraulic pump allowing the mercruiser pump to be removed? less parasitic drag=MORE POWER
...Has anyone ever tried this??? or maybe as an emergency back-up?
Thaks guys for all the information....I was gone to the lake for a few days.
Old 01-14-2002, 04:38 PM
Charter Member #927
Payton's Avatar
Post
I really don't know. you'll have to be sure it has enough flow. I would think it'll be more drag and wear on your electrical system.
Payton is offline
Quick Reply: Charlyn helm part # ???
