Outdrive Oil
Geronimo36
I would say its leaking pretty good. A 20 minet ride to get the boat back to the launh and pull it out the whole reserve bottle was empy again,
Can it come threw the u joints ? I read a past pot here and that was what other though about a simular issue.
Also any good mechanic shops in CNY - Cicero are with a quick turn around time ??
Before you bring it in tell the service tech what your serial numbers are so they can make sure they have a spare yoke in stock. Sometimes just the seal goes bad and you can get away with polishing the yoke up with some 1K grit wet sand paper, other times it wears a groove in the yoke and you need a new one. It's also a good time to re-seal the rest of the upper end (make sure they replace the shift shaft seal)
OSO Moderator
Sounds like you blew the carrier bearing seal on the outdrive.
Kinda common.
http://www.mercruiserparts.com/Show_...%28STANDARD%29
#28 - 31
Kinda common.
#28 - 31
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
IMO ?
Is that the same as a carrier bearing seal or yoke seal ?
Sounds like there could be many places that would cause this issue. I called a local guy to see what there turn around time was and he said most likely the input shaft . So now Im fairly sure I need to have some more knowledged then myself look at it.
SORE MEMBER
1 Post
IMO ?
I used to encounter that problem on occasion, now, when filling the drive, I re-install the top plug and continue filling from the bottom of the drive until I see a minimum level in the reservoir, at that point I stop and top up to the full line. This seems to eliminate any air pockets.
Have someone watch the reservoir, as it is easy to overfill the bottle using this method.
Geronimo36
IMO ?
If you call it a "carrier" seal they may get confused (or at least I would) and think you're referring to the propshaft seals or the o-ring that seals the propshaft "carrier" in the lower unit.
No biggie just remembering when people would explain stuff to me and customers not being able to explain what the problem was...
![Drink](/forums/images/smilies/drink.gif)
