Pump gas, compression, and boats....
OK, opinion time:
How high of a compression ratio do you think is safe for pump (91/93 octane) gas?
No knock sensor, so no safety there.
I'm leaning towards something such as: You need not plan building a boat engine that depends on 91 or higher unless you have your own fuel truck, and or never plan on traveling out of range of said fuel truck and or inland gas station. High compression boats, turbine boats..ect. ect...Having to plan your every move around the fuel guage and present location takes a HUGE! chunk out of the boating fun factor.
OK, opinion time:
Michael
If this is a N/A engine build. I have run as much as 11.5:1 on 91 octane with no problems. There are some key factors of course which go with keeping them alive. Aluminum heads , water temp through engine 125-140 , ignition timing, Water volume to engine, and fuel curve. If you want to be very conservative .....not knowing every detail of your set up....stay around 10.0:1
21 and 42 footers
I'm running 9.75 compression 540's. Dyno pulls were made with 93 and 89. 93 was fine of course, 89 could be run comfortably up to 4,000 rpm's. Once approaching 5,000 the knock sensor starting going off. If I'm ever out of range of 93 octane pumps I just need to keep from hammering on the throttles and everything should be fine. This info came from Mark at Precision Marine in New Orleans.
No blowers, N/A for the win...
With 64cc heads (which I have not aquired yet) we would be pushing 11:1.... Now I am going to go with larger cc heads to keep the compression down. 10.6:1 pistons and they took .080 off the deck, also had to go .040 over. #8 cyl had a bad taper to it.
