How do I cut Stainless boat lift cables?
#31
Gee I must have been imagining the 10 years I spent in the boat lift business cutting all those stainless cables. Get a big pair of bolt cutters and it'll cut like butter.
Naturally the right tool would be perfect, but I don't see him buying cable cutters for 1 or 2 cuts. If he doesn't have the bolt cutters, a cutoff wheel works great as well.
Ever wonder why they are called " BOLT " cutters ?
#32
Thanks Chris , that is what I meant .. Never said nothing else would do the job ..Only that the proper tool always does it better.
#33
Rob
My cheap bolt cutters want cut it ,it made a mess of the test picse. I did use a cut off wheel, but it still wants to unravel. The factory wire looks like it has some kind of soldier on it?
The pick on the MSD coil I cut with a cut off wheel.the other look cut with a torch or something?
#35
Rob
with a regular type solder gun? I dont think I can get the cable hot enough with it? will the alum solder hold?
#38
Rob
I have a small little hand held torch,what about the solder?
I also have the liquid electrical tape ,will that be strong enough to hold it together?
