How do I cut Stainless boat lift cables?
#42
Registered User
The torch-cut photo appears to have been done with a plasma cutter. Excellent approach- it cuts cleanly and fuses the stray strands.
I use poly stretch wrap- the stuff they bind pallets with. They have it at OfficeMax and U-Haul. It wraps the cable but it is still thin enough to go through ferrules, etc. Duct tape usually isn't. We use a modified hydraulic hose cutter in the shop and a 5" disc grinder with 1/16" cutoff wheels in the field. Both work very well.
#43
Strip, if you don't go out and spend the $$ on a plasma cutter to cut your weany boat lift cables you're gonna be the shame of OSO
#44
No, this is not my lift but what you're gonna end up with in order to clear the beams when it winds. Guess this was done before they went to stainless clamps.
Before everyone jumps on the "cut too close bandwagon" the clamp is just to keep the cable from backing out of the roll pipe. As long as there is 3 turns round the pipe at the lifts lowest position then there is no load on the clamp. Much more than that sticking out of te clamp and it's not going to clear.
#45
Strip is cutting BOAT LIFT CABLES, how is this even revelant??? This thread has way over complicated a very simple task. 1000s of lifts go in every year and I haven't seen one done that didn't either have factory plasma cut ends or taped then bolt cutter or cutoff wheel cut.
Bolt cutters are not meant for cutting wire rope. You CAN do it yes.
Im sure noone except us 3 give a hoot.
SLINGSHOT
07-10-2006 07:54 PM
Formula Outlaw
09-28-2004 08:44 AM
